Incredible build, you have done a really amazing job on your bronco. Very impressive considering you have done the majority of the work yourself, most people couldn't do half of that on their own.
I couldn't find any decent soldering tips so I bent up my own using solid core copper wire. It works fine and is much cheaper.In the meantime, I've been working on wiring, it's a slow go, but it is going. I hate my soldering gun~ I ordered some new tips and solder and see if that will help. Finally got the hose connected to the gas tank, just waiting on some hose clamps. Just piddly things you know; makes progress seem very slow. The ignition switch is wired and engine will turn over I'm confused on which type of transmission fluid to use for my C4? I asked the guy that overhauled it, but forgot what he said.
dne'
I used to use a soldering gun. I liked the instant heat. But after using a pencil style iron at work, I realized that once heated up the pencil style was a lot easier to handle. Especially for automotive work.
I still have the gun, but haven't used it in over 30 years. Most of the time it's just a 25 watt iron, but I have a larger one for cable work. As for the delay heating up, I just plug in the iron while I'm getting everything else ready & keep it hot throughout the project.
I have a spring stand to rest the iron in while it's hot. And just like the gun, it's important that the tip is tight before heating it up. And tin the tip before each use. The tips also last a lot longer that they do on a gun.
Not mine, but these look similar:
