Dne007
- Jul 18, 2021
- 539
Yes, I did just this about an hour ago. doing so the needle of the gauge moves all the way. So, that may rule that the sender is incorrect or not grounded as you said. I was re-installing the speedo assembly and I keep knocking the high beam indicator from its hole! grrrrr
in the morning I'll make sure to ground: engine to body, metal dash to tub, etc. I have a negative running from the battery to the body.
I really don't think I got anything done today~ but's nice to be in the garage doing something.
dne'
Thanks guys!!!
dne'
Thanks guys!!!
Take the wire off of your temp sending unit and ground it to the block. If the gauge moves then you have a wrong or bad sender, or the sender is not grounding to the block.
