freedomof76
- Apr 26, 2017
- 7
I'm building my first early Bronco with the help of my brother in law, and we have hit another roadblock. A couple of factors have thrown off the rear geometry quite a bit and the rear driveshaft is sitting at 30 degrees. Here are the specs for the restoration.
360 HP Boss 302 from Ford Performance Racing
Ford C6 transmission (2.5 inches longer than C4)
Dana 20 transfer case
Ford 9" rear axle
3.5" Wild Horses lift
Will run 35" tires @456 gear ratio
We used 8 degree shims and the rear axle is now at 70 degrees - we are concerned that any more could affect the oil in the rear axle. Even with the 8 degree shims the driveshaft is still at 30 degrees.
What options do we have to fix the issue? If we leave it at the current angle, will we have a vibration (I'm assuming yes and we could also snap the driveshaft?).
I'm a noob, my brother in law has a ton of experience with cars but not Broncos or lifts.
Ford 9" rear axle
