73 Bronco head lights not working
malibubronco
The headlights on my 73 do not come on but the parking lights and blinkers work fine. The Bronco has not been on the road for a while. Wires seem to be OK. Lil help?
I would start at the high beam switch. With the headlights on, cycle the high beam switch a couple dozen times. If you get any light at all, even just a flicker, replace the switch.
Next break out the test light (or meter) and check for power at the 3 wires on the high beam switch. Two of the three wires should have power in either position (One in, alternate of the other two going out).
Nothing at all getting to the high beam switch? Check the headlamp switch itself.
Everything happy at the high beam switch? Check for power at the bulbs.
The high beam switch is a common failure point and also cuts the trouble shooting for the other parts in half. So that is where to start.
