sstlaure
Bronco Slacker
- Jun 7, 2004
- 1,881
I'm going to make my own equal length stainless headers (1 3/4" primaries) and in order to fit them, I decided to remove the stock engine mounts (they take up a ton more room than necessary. I'm trying to minimize how far fwd I do put the motor to keep weight dist good for flight time. (about 1/2" clearance at firewall currently) I'm also trying to keep the engine as low as possible to give me the clearance on top for the supercharger and to keep the CG down. The custom motor mounts make all of that easier, and it's not a big deal to make the mounts myself as I already have some bushings that fit into 1 3/4" tubing.
My lift is maybe around 4", but I compress way up. My driveshaft at full compressed is ~1" from the bellhousing. I think my truck compresses more than a stock Bronco does and maybe that's why the pan will interfere. I looked at the HP44, but the driveshaft would be through my bellhousing with where my truck sits at full comp. Maybe the top of the diff is shaped a little different where it will clear the pan? I'll have to look at my friend's truck, he's got a custom HP44 in his truck (center diff)
@ Full extension my driveshaft is at ~32 degrees, so I'll be going high-angle on that to prevent bind (full 14" of travel front compressed to extended.)
My friend with the Green prerunner had ~520 hp the first season he had it together (331 stroker) and yes it was scary fast, but in the sand you need the extra oomph to spin up the paddles. He's running close to 1000hp in that same truck now and it's controllable. (13.5:1 408 stroker and 2 stages of NOS) I don't need that kind of power, but I really like the way his performed with the 331, so that's my target. I should be really reliable at around 500 rwhp.
Definitely going with the clockable starter. I'll also be going with a remote mount hydroboost unit so that all I need on the firewall is a small slave cylinder. Trying to keep the engine bay clean to show off the motor.
