The latest plan (most accurate so far) has 12" front travel/16" rear. (5.5" susp lift, 2" body, I'm going to cut the fenders larger for more tire clearance)
FRONT
The front will use a 14" travel shock mounted in front of the coil to achieve the 12" travel (Still need to figure out exactly how I want to mount the bottom end to the radius arm, probably some bracketry on the clamp end of the rad arm) Used basic Trig to calculate the shock length based on travel. (If you need more info on this, let me know). Stock radius arms, 78/79 drop brackets, 7.5 degree bushings (still not sure about the caster, may need further improvement, still looks kind of steep). The arms don't seem to bind up the way they did in the 66-77 rad brackets. Top mounts will be custom hoops w/cross brace across the top of the engine
REAR
16" travel shock mounted straight on top of the spring perch (I'm probably going to machine something cool for the u-bolts and lower shocks mounts to be on...we'll see) The upper mounts for the shocks are in the roll cage, with the shock passing through the floor. I'm going to make some kind of center mounted single ladder link to control axle wrap.
Brett from King said that as long as the shock can bottom completely out, then they will perform correctly, so bottom out the susp. bottom the shock, and bottom the bumpstops, set this as full compression and work backwards from there.
In my case, I'm going to pull the leaves/coils to set the susp at full compression, because the rear axle will follow the radius of the ladder link and stay in the proper position. you could probably ratchet strap the suspension down, but be careful releasing the tension if you try it that way...(unfortunately speaking from experience %)%) Stupid strap.
Just for giggles...If a person were to offer a suspension system similar to what I am building...what would people be willing to pay for it??? It would include.....
> King Bypass Shocks/airbumps ($3K retail for shocks/bumpstops)
> Full cage tie-in to frame 6-8 pts (needed for rr shock mounts)
> Custom cage or fabricate mounts into existing cage
> Vehicle would have to be 2 or 3 seater.
> All tubing would be raw/unpainted 1 3/4" x 0.120 wall DOM
Got some funny ideas floating around in this head of mine. The way this truck is designed is a ton easier to fabricate than the green machine, we may have a marketable product if there is enough interest...(need good insurance for this kind of thing, that can't be cheap...people will do some seriously stupid things then blame everyone but themselves...)
