JusticeJMB
PM sent on door latches
This is what i have left. The price listed is without shipping, but will ship for actual cost of shipping. I can get pictures on request.. Thanks,
Footman loop ......$10
rear axle ubolt plates and old u bolts...$10
Under hood steering column hole cover plate...$5
Set of radius arms and caps....$50
2 Rear Fuel tanks....$50 each
2 Heater boxes ...$40 each
factory air cleaner...$30
driver and passenger fresh air vents... $25 each
set of drum brake spindles and hubs...$40
set of d44 axle shafts...$40
fuel filler necks 1 aux. 2 rear...$15 each
2 track bars...$20 each
2 j shift t-case one good for housing.$20...one good just needs input shaft.$50
76 stock pitman arm...$20
70 manual pitman arm.... $20
manual steering box..$40
stock 70 steering linkage.. $40
Pedal assembly, no pedals...$15
2 sets of window regulators... $30 Each
2 T/C cross members... $25 Each
taillight buckets... $25 pair
Coil cups .... $20 set
Tailgate Hinges and straps...$20
Door hinges...$25 set
Door straps...$15
Door latch Mechanisms... $30 set
Inner door handles...$5 Each
70 Manual steering column..$50
set of 4 steel black painted wagon style wheels 15X7 ....$100
2 sets stock hieght coil springs...$40 each
Metal Fans 2- 5 blade, 1- 7 blade....$30 each
Trans cooler 6 pass.. approx. 8" x18".....$20
defrost duct....$30
misc. trim pieces....$Offer
plastic column bezel...$10
used ring and pinion gears with open carrier i believe 3.50 ratio... $offer
hard top in good condition except for the top panel has quite a few rust holes in it....$100
I think this is everything I have left i will post if i find something else...
