Bronco_46256
I am in need of a few measurements off of a thrust bearing from a 302.
First, I need to know the overall with from outside surface to outside surface. These would be the surfaces that the crank would ride against when it is moving backwards and forwards.
Second, I need the thickness of each side of the bearing surface that the crank would ride against.
I need this to do some determination of exactly how bad my crank end play is. It’s a little above spec and I want to see how much total surface there is before I wipe out a bearing…….
