retherford
When I got my '76, the speedometer didn't work so, I removed the cable from the transfer case. There was no speedo gear on the end of the cable. My question is: does the gear just slide onto the cable and then I insert the cable with the gear attached into the transfer case or is there a seal and/or clip that needs to be attached to the gear before I do this? This is my first time working with speedo cables.
