76BroncoTWJ
Hi all, newb here.
I just bought a 76 Bronco. Been wanting one for years, so I'm pretty excited. The guy I bought it from said it hasn't been started in over two years.
I pulled the plugs and shot a little Marvel Mystery Oil in the cylinders, then rotated the engine manually to see if it would turn easy. It did.
Next I put a battery and a set of plugs in it, poured a few gallons of gas in both tanks because I don't know which is the main and which is the reserve, and tried to fire it up. No good. Not even a sputter.
Shot some starting fluid down into the carb and she wants to start, but as soon as you quit shooting the starting fluid down that throat, it quits trying to start.
Disconnected the fuel line from the carb and spun it over, no fuel.
Crawled up under it and disconnected the fuel line from the tanks to the fuel pump, and fuel comes out.
My first thought is it's a bad fuel pump, but I'm good looking, not smart, so I figured I'd ask some people who knew more about it than me.
My buddy who is a lot smarter than me says he wonders if the fuel prump just needs priming or something and wants to jack up the back of the Bronco so the gas has an easier run to the fuel pump so it won't have to work so hard.
I'm not so sure about that one.
Does anyone have any advice?
Thanks,
TWJ
Thanks,
TWJ
