77 e-brake help
mpboxer
Queen Creek, AZ
Working on a friends 1977. He doesn’t have any of the welded on bracketry (first picture circled in red). I’m just confirming this is needed? All the other years that I’m aware of require it.
I’m a little confused about the next two pictures. Was 77 the only year for these pieces? Does anyone have a picture of them installed? Why is the center e-brake cable threaded?
Thank you!
Mike
Bronco-Brian
Lake Oswego, OR
My '77 doesn't use the cable extenders. The cable equalizer is unique to '77 as it connects directly to the primary cable w/o the pivot arm. See photo.
mpboxer
mpboxer
Queen Creek, AZ
That is fantastic news! So I don’t need to weld on those brackets. Not even the one near the fuel tank selector? Just go straight from the e-brake lever in the cab to the equalizer in your photo?
mpboxer
mpboxer
Queen Creek, AZ
Correct. The '77 center cable is unique with a threaded end. See TBP p/n 2700.
Cool, I saw that (second picture from original post) but was confused. One more question, so the only thing keeping the cable from flopping around under there before going thru the equalizer is the little bracket that holds the speedo cable also?
Bronco-Brian
Lake Oswego, OR
Mine looks like your photo. I added another shot of the center cable connection.
