87 F-150 engine swap
hdfx81
OK, I know these questions have been asked a million times here but the ones I have found ask mostly about car donor engines. I have a lead on a recently rebuilt (approx.10K) 302 out of a 87 2WD f-150 w/5spd. I know i need a clutch equalizer bracket and I have to use the 87 harmonic balancer and flywheel and I will be using my carb and intake. My questions are, can i use the 87 clutch and pressure plate? they were new with the rebuild,will my stock bellhousing and starter work? I'm pretty sure it has serpentine belts,can I use these without any rad. clearance problems if not will my stock pulleys work? Can I use my water pump w/passenger side outlet or do I have to use the 87 wp and a hose extension?Can I use the 87 oil pan or do I use mine and my oil pump pu?Anything else I have to do? The motor is only costing me $300.00 and I know the guy that rebuilt it he said he went totally thru it and it is a great motor The frame rotted out and that is why he is selling it. Oh yea it's going into a 73 bronco.
Thanks in advance for any help?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I'll take a stab. As long as the clutch disc from the '87 is the same spline count as your transmission input shaft, the clutch and pressure plate will work. Bellhousing should bolt right up, not sure about the starter. Depends on the tooth count of the fly wheel I believe. If it has a clutch fan on the front, you will have a hard time fitting it in the EB engine bay without modifying your core support. You will be able to remove the serpentine setup and use your stock front dress. Oil pan needs to match the EB in order to clear the front differential. I am by no means an expert, but based on all I have read and worked on over the years, dropping the '87 5.0 into your bronco should be fairly easy to do with minor adjustments necessary.
