It's an engine, can't say it's the one you want. It can be made to work.
It is NOT mass air. It isn't even sequential EFI. It is a plain and simple as can be, barely port injected batch fired speed density EFI. The engine should still be the old flat tappet style as well (although getting close to when all 302 went roller). But it is a roller compatible block.
Personally it would be just about the last choice in EFI systems to try and adapt.
Double check the trans. Some were AOD, some were E4OD. If the shifter has an OD cancel button it is the E4OD, also the trans pan is 20" long. The AOD does not have a "2" in the shift position and has a 14" long trans pan. The AOD could be used, but the attached chain drive transfer case is too wide to fit in the Bronco frame rails. The Bronco D20 transfer case is a different bolt and spline, but adaptors do exist. Also consider what shape the trans is in? The AODs generally don't age that well.
So while it is an engine and transmission that can be made to work, not exactly high in the desirable list.
