jason.k
My current 9" is a small bearing axle and I want to source a big bearing 9" and add disk brakes. The more I look to build one the more expensive it gets. So I was wondering is there a reason why I haven't seen anything on swapping rearend's out on the early bronco's? I see a lot of threads about rear disk brake conversions and plenty of venders sell them it just seems to me a lot of mismatched parts to make it work. Maybe it is the only way to do the conversion that's why im asking this question.
Would it be easier to find say a 1977-80 Lincoln versaliess that came with 9 inch rearend and disk breaks from the factory? I know it would need shortened to fit under bronco like the stock one does but what else is different? Bearing size, weaker axles, ect.
