SaddleUp said:
Look on the drivers side at the top of the housing just inside the u-bolts. Normally the vent line fitting doubles as a bolt to hold the brake T. You can see the one on mine hanging down in the pic below. Keep in mind my pinion angle is pretty steep so yours is probably more toward the top. If you just put seals in it a year ago then I would only change them if they are leaking. You mentioned that they were leaking in an earlier post. Even if you think the leak is caused by it not venting I would still replace them if they are leaking after you fix the vent.
Oh, that...yeah, I got one of those. There goes that theory %)
Anyway...I put new shoes and wheel cylinders in plus the new drums. All stuff from the 76-77 brakes...and it works!!
Time will tell if there's any leakage, but I'll be watching it...right now though, (after 1 day) it all seems to be A-OK. Didn't do the oil seals or the bearings...mostly because it needed to be done for work today and I didn't have the tools to change the seals.
I was told that the seal was leaking and that's what had gunked up the passenger drum, but it didn't really seem like it was leaking. How would I tell? There was still grease on the bearing. Would it all get washed off if oil was leaking through? I guess I'll open it up in a week or so...that should be long enough for any problems to show up right?
Thanks again for the help.
