kiteoregon
- Nov 21, 2011
- 292
When i had my short block built, i vaguely recall something about the ability to run a mechanical fuel pump. I assembled the motor with a universal timing cover with a spot for the mechanical fuel pump, so i am thinking that i am set up for one. Now that i am planning on the Exp 5.0 Serp front dress, i believe that i read somewhere that the provisions for the mechanical pump will cause issues with the explorer timing cover. Is this he case? Since i will be removing the water pump, balancer and cover is this something i can fix when i am in there, or do i need to have a machine shop do the work?
KO.
KO.
