ugh, the list of issues ive run into with this swap is silly. trying to stay positive with the small wins everyday of the build but these are frustrating. when you call customer service because the aftermarket serpentine kit doesnt fit and they ask you what year motor you have. "sir, i have a 95" "um, oh, thats not good".
anyway,,,,,,, i have a 1995 mustang 302 going into the bronco. the timing cover and water pump need to come off and get swapped out because i cannot run just a reverse water pump and the timing cover because im running just an alternator and it needs to spin the other way. the timing cover needs to change because the water pump pulley hits the cover.
so my questions are these. can i use the original timing cover from the bronco or a similar. i would like to run a mechanical fuel pump but the current motor is an electric fuel pump. can i run a mechanical fuel pump with this motor? if so what is needed?
im sure more questions will pop up. thanks for your time guys. your help is appreciated.
