The previous owner stated that a new stock-height suspension was put on to replace a 3.5" lift. It has Tom's branded shocks, so I'm assuming it's their kit. The truck rides pretty harsh/stiff and has the occasional clunk in the rear, so I started poking around a bit...
My goal is to have something that rides nicely on the street and can handle very very minimal off road (we're talking gravel/dirt roads, nothing crazy). I like the stance how it is.
First, it looks like there is maybe a worn bushing on the shackle on the driver's side? Should there be so much space side-to-side between the shackle and frame? I'm guessing I at least need to replace the bushings? Should I upgrade the shackles or do anything else while I'm at it?
I also think the leaf springs are installed backwards? Can someone confirm?
Front:
Rear (looks like double wrap):
Will fixing this cause the front tires to move forward in the wheel wells? They already seem a bit forward of center...
What the heck are these things on top of the retainer plate?
There are no bump stops in the rear:
Do stock style bump stops (https://www.wildhorses4x4.com/product/Rear_Bump_Stops_Pair_OEM_Style/bronco_rear_suspension_parts) just fit onto the brackets or is there some sort of fastener? And it looks like my exhaust might be in the way?? Is this common?
Lastly, there are spring spacers on only the front driver's side spring. I'm guessing there was "bronco lean" and they did this as a quick fix? So I need to try to fix it the right way? (https://dufftuff.com/what-is-bronco-lean/) Is there any other reason these would be on there?
Ugh, so many things...
![IMG_9384.jpg IMG_9384.jpg](https://classicbroncos.com/forums/data/attachments/905/905960-034de431fb7743d78760ff4733b0d088.jpg)
Front:
![IMG_9393.jpg IMG_9393.jpg](https://classicbroncos.com/forums/data/attachments/905/905961-afd8369667af996dbade33f2208f52a9.jpg)
![IMG_9390.jpg IMG_9390.jpg](https://classicbroncos.com/forums/data/attachments/905/905962-a36e5c06fb38acc0aaad0ede11b7fc3e.jpg)
![IMG_9385.jpg IMG_9385.jpg](https://classicbroncos.com/forums/data/attachments/905/905963-b203022db09eaded4405495b84e3af79.jpg)
![IMG_9387.jpg IMG_9387.jpg](https://classicbroncos.com/forums/data/attachments/905/905964-b1736c1290fe30785add826605aa8a6d.jpg)
![IMG_9388.jpg IMG_9388.jpg](https://classicbroncos.com/forums/data/attachments/905/905965-6ab9e18dcf1e21419bf7bce0c2df782e.jpg)
![IMG_9389.jpg IMG_9389.jpg](https://classicbroncos.com/forums/data/attachments/905/905967-2e39053c727fad6ca13767cfad9e1523.jpg)
