AAW wiring harness Question
pk8950
Solon, Iowa
I am installing my wiring harness and have a question on 3 wires for the steering column. I have a 74 bronco and am installing a AAW harness.
#1 AAW harness Yellow, (Left Front turn) Hook to yellow off of stock column, but I only have a yellow with black stripe off stock column. Is this the wire?
#2 AAW harness Purple, (turn switch feed) Hook to blue on stock column. I only have a light blue wire and a light blue with red stripe wire left. Which would it be?
#3 Where does the remaining wire attach?
Function is more important then color. Sounds like you may have a turn signal switch (or column) that is running different colors then when the manual calls for. time to figure out your steering column.
a74ranger
Athens, GA
I had some trouble with this as well. Check out this link which helped me:
http://www.tomsbroncoparts.com/page...-early-ford-bronco-turn-signal-switch-wiring/
You can match this up with this AAW harness on Page 8 (http://www.americanautowire.com/PDFLink/92970069 510317 IN 3.0.pdf).
The AAW link is updated from the instructions that came in my kit and seem to be more detailed.
