- Oct 14, 2004
- 5,001
How do you know how tight to set? Put these in resealed case because I had them. Case was not popping out of gear, but changed all the gears to tera low and replaced all the gaskets, seals , etc. Did not replace the input and output bearings so none of those specs have changed. Wondering if I should put the detent springs back like it was since I wasn't having any problems.??
