Advance Adapters AOD KIT PROBLEM!
Bhall75
Atlanta
I ordered an AA AOD kit and new bushings from Bronco Graveyard and that is when the problem started. The original bolts (2) that were removed from my cross member were 9/16 outside diameter and the bushings are 9/16. I even bought a stock set of replacement bolts from Bronco Graveyard and they were 9/16. AA is telling me that from the factory, Early Broncos had a 1/2 bolts, not 9/16. My issue is the adaptor is tapped for 7/16 bolts and I have 9/16 bushings (from energy suspension) and 9/16 bolts. Has this happened to anyone else!?
B
Bhall75
Atlanta
The kit did come with sleeves and bolts but they are 7/16 sleeves and bolts, not 9/16 sleeves and bolts.
broncodriver99
Glen Allen, VA
Yes, because the housing is threaded for 7/16" bolts. There is no way to use the stock bolts unless you want to drill and tap the housing the larger size. Is there a reason you can't use the 7/16" sleeves and bolts?
B
Bhall75
Atlanta
My main problem is that the bushings are made for the 9/16 bolts and not the 7/16 bolts. With the thickness of the sleeves, the 7/16 bolt and sleeve is not big enough. It will damage the bushing because it doesn't fit tight.
The bushings are a lot more tolerant than you are giving them credit for.
B
Bhall75
Atlanta
I ended up grinding the 7/16 sleeves on a wheel grinder and sliding them into the 9/16 sleeves. Did this by putting a bolt through them.
