Advance Adapters AOD to D20
SevenT
Southern Colorado
Bronco Gurus,
I blew up the clutch in my '70 and decided to go with the AOD that came out of the donor for my EFI swap. I am having the AOD rebuilt and the adapter installed. My question is: How much disassembly is required on the D20 to accept the new spud shaft??
TIA,
SevenT
needabronco
Prescott/Farmington
The spud shaft is part of the adapter, it'll come out when you pull it off. You will have to pull the inspection cover off the D20 to fish all the needle bearings out of the bottom of the case, but that's it.
the output shaft in the trans has to be replaced as part of that kit.
The output is the last piece removed and the first installed when doing a complete build.
The whole trans has to come apart. Ervery rotating part comes out and back in.
