Advice on Drivetrain Selection
sooner-sig
Horn Lake, MS.
Okay so I just got a 71 bronco that needs a ton of work. Ultimately will be a once a week driver, go camping and such kind of truck. But I still want to take it to the deer lease and run it through some Mud of course. So with that being said I need a reliable drivetrain so if I want to go on a 4 hour trip or just have enough power to go muddin. It's got a rebuilt 302 in it now. I'm thinking about just converting it to EFI. what tranny and t-case set-up would be ideal for for what I want to do. Right now it has a C4 and Dana 20
Thanks for any help, and if anybody lives in the southaven, MS. area and wants to help out let me know.
bigmuddy
Marthasville Missouri
Stick with as stock as possible for reliability and a 302-C-4 with the D-20 is perfect. You didn't mention tire size but a set of 4.11 with 33's is a great combo.
Ben
I will ask a few more questions;
1) what tires does it have (will it have)
2) what is the current gear ratio in the axles
3) do you prefer an auto or stick
4) how much highway driving do you plan and how fast
There is a good chance you already have the drivetrain you want.
EFI can be added to the old 302, no problem.
S
sooner-sig
Horn Lake, MS.
1) what tires does it have (will it have) It has 35" on it now
2) what is the current gear ratio in the axles I've been told 3.5
3) do you prefer an auto or stick... no preference but I would love an extra gear for highway driving
4) how much highway driving do you plan and how fast once a week on the highway the occasional trip to the lake deer lease etc. 70MPH
Thanks for the info guys
OK, I see 35" tires and 3.5 gears. I worry. I bet it is a little sluggish off the line. You are working the torque convertor hard, that is inefficient and generates a lot of heat, which is bad for the transmission. I am predicting a short transmission life with that combo. 3.50 gears are only good up to about a 31" tire if you want an automatic to live.
I have a couple of thoughts. One is lower gears, how low is hard to say. 4.10 might be enough, 4.3 sounds a little better, 4.56 is probably too much for the highway. If you are doing an overdrive then start at 4.88
Another option would be a 435. You would be using a lot of granny, but it would be like a real nice overdrive on the highway.
Then 4.56 gears with a NV3550 would be real nice as well.
You probably wouldn't like the simplist idea, get a set of 31" tires. It would probably be the cheapest. Less frontal area to push the wind would probably get better mileage as well, especially if you un-lifted it.
