Need advice on replacing drivetrain seals
kaw550
I have a few minor leaks from the oil pan, 3spd and transfer case. I want to replace the seals including the rear main.
I am planning to pull the 3spd and transfer case to get a look at the clutch.
I was hoping to get some tips before I just start pulling everything apart.
Should I remove the trasfer case or pull both in one shot?
What the best way to lower them from the truck?
Is it easier to do the rear main seal with them off?
How do I support the engine with the pan off?
I saw JBG sells seal kits. Can all the seals be installed from the outside or do I have to crack them open?
Should I just keep parking on plywood?
Any other tips?
Viperwolf1
electron whisperer
It's a lot of work to pull everything out. Even more work to put it back in. I suggest getting some pictures of the leaks on the tcase and trans. You may be able to fix those in-place.
farnorthdan
Eagle River, Alaska
We just finished pulling/rebuilding the entire drivetrain from my 73', its alot of work. We pulled the drivelines, then the Tcase, then the tranny, then the bellhousing and cluch/flywheel. I had everything rebuilt or replaced. Getting everything out and cleaned up was by far easier than putting everything back in. The Tcase was a royal pain to get back in, it weighs over a 100 pounds and you kinda have to do it by hand, that by far was the hardest part and definately a multiple person job.
My opinion is that if your going to be pulling the drivetrain you might as well fix anything that needs it while you have everything out. Its kinda spendy but well worth it in the long run.
Dan
kaw550
kaw550
I ran out and took some pictures.
It is definitely leaking from:
The back of the transfer case,
The output for the front driveshaft on the transfer case.
The gearbox is leaking from where the shift linkages mount
The bottom of the bell housing and the oil pan were wet but I could not determine where it was coming from. Maybe where the dipstick enters the pan or the oil drain bolt.
I cleaned everything with brake cleaner and paper towels. I will check it again in a few days.
(Part of the reason for pulling everything was to get a look at the clutch and flywheel. I have some chatter. If I could surface the flywheel it would give me some time to decide if I want to keep the 3spd or use a C4 that I have.)
fromme
Suffolk, VA
When are you going to show us pics of the big leaks? ;D
Looks like mine. Good luck, but it's a lot of work to fix that kind of thing. Not that I'd love to have a leak free rear axle, t-case and trans; but I haven't been able to muster up the motivation for disassembly to fix them. It's a lot easier to keep filling it up, lol.
Viperwolf1
electron whisperer
A little trick on the tcase is to use some thread sealant on the bolts. All except 7 of the holes (6 in middle on bottom and the one holding the countershaft retainer) go right through to the inside. The front output seal is bad. I recommend you replace that without removing the retainer. There's a gasket under it that helps set the endplay of the front shaft. If you don't put it back on or use one that is thicker/thinner it could lead to problems. The countershaft looks like it's leaking at the rear. You can remove the retainer and knock the shaft back out about 1/2". Then you should see the o-ring that seals it there. Put a new one on and tap it back in.
Trans shift seals can be replaced without trans disassembly. Use sealant on the adapter bolts there too.
Check valve covers and back of intake manifold for the bellhousing drips.
You can fix most of those leaks in place but not all.
kaw550
kaw550
Viperwolf - I think your right. Most of them could probably be fixed in the truck but I wont be happy when spring comes and thee is still clutch chatter.
I need to get a look at the clutch and flywheel.
Should I bring it down in one piece or do it in stages ?
I have long tube headers so I may have to separate the MT from the bellhousing.
