AFI wiper motor problem
twisted 66
Norcal-Tracy
I have done the electric wiper upgrade you get from WH and changing the passenger side to 80 and the driver side to 110. Problem is it only seems to have a 90 degree sweep. The pic shows the wiper pattern that cleaned the dust away as well as where the wiper sits when off...Is this normal or do I have something set up wrong?...Thanks in advance
badmuttstang
redneck grease monkey
Just pm'ed you if they are in fact 110° motors you should get more movement out of them than that. It looks like they are 80° motors which will give you a sweep pattern that looks like that.
twisted 66
twisted 66
Norcal-Tracy
I did confirm they have the correct part number indicating a 110 degree motor, pn#AFI 34010 stamped on the back. Maybe something is off inside, I am going to WH tomorrow to see what they say..
If you did it per the manufacturer's instructions, I don't see how you could have done anything wrong. But I was under the impression that we pre-set them at the correct spacing before you get them.
So did you actually change the driver side too? If so, you might try putting it back the way you got it just to see what happens. If this is the '66 in your name, then the passenger side is the only one you need to change.
Either way, I'm sure you can compare at the shop, or exchange it if nothing pops right out as out of whack.
Good luck.
Sorry I won't be in tomorrow to at least say hi.
twisted 66
twisted 66
Norcal-Tracy
Good luck.
Thanks Paul,
The only one I changed per your instructions for the 66 was the passenger side. Hopefully I can get it figured out tomorrow morning at your shop.
twisted 66
twisted 66
Norcal-Tracy
Can anybody with these AFI motors verify how far the blade sweeps compared to mine in the above pic?
Jdgephar
My '68 has the AFI motors. Definitely sweeps farther than that.
twisted 66
twisted 66
Norcal-Tracy
I talked to the tech support line and sent him pictures as well as the cam plate inside the motor. He said there might of been a manufacturing problem in the degree hole locations on the cam plate. They said my cam plate should look like the one in the instructions which is attached, clearly it does not as seen in my pics. Their suggestion is to move the wiper down several inches away from the seal to clear more rain in my view. I am going to run it and probably drill another hole in the plate and lengthen the transmission rod plate to see if I can get it to go further.
  • MRV Wiper book.pdf
badmuttstang
My cam plate looks the same as your sorry I didn't get a chance to message you yesterday I took a picture of it so you can compare them but as stated I am getting more movement out of mine not sure why.
