AFR gauge
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Thinking about installing an AFR gauge and want to know what you'd recommend. I'm in the military and we're looking at moving within the next 8 months ranging from Colorado to New Jersey. I think a wide band would save me time getting the afr/carb dialed in, and am unsure of the difference between wideband and narrow band AFR gauges. Thanks in advance.
Madgyver
Bronco Madman
I've been wanting to do this AFR guage...
Do you need 2?
one for each bank?
Do you need 2?
one for each bank?
With true dual exhaust, it's the best way to get full accuracy. But do you have to? Not really. It's just "better" to do one in each bank.
If you have a 2-into-1 exhaust, or even a dual with a connection (H-pipe, X-pipe, Crossover tube, etc) then you can more easily get away with a single I would think.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
One guage, two sensors.
Unless you have something mechanically wrong, what the left bank puts out will be the same as the right bank.
If you are tuning cylinder to cylinder, multiple sensors. But the general overall picture, single sensor in either bank is fine.
If you can get someone with the motortrend app, the latest enginemasters ran a whole bunch of AFR stuff. Different brands, different locations, etc.
Madgyver
Bronco Madman
I have a Y connection 2-2.5" that goes to a single 3" inlet exhaust. Could I mount the single AFR port there?
nvrstuk
PNW
Been using my Autometer WB for 8 yrs. It has digital output of course but also a small ring of LED light around the outside so at a glance you can quickly see that you are rich or lean or right on .
I've heard of issues with other brands but my buddy who posted earlier about his (rocknhorse) hasn't had any issues.
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
Yeah my Innovate has been great as well. I run one sensor in the driver side down pipe ( only because it was the easiest side to mount in). It also has a digital display and a ring of LED’s like your Autometer. A cool feature is the ability to run it with either a white or black face.
rocknhorse76
Central WA
Not sure about other brands, but Innovate recommends mounting the sensor about 12” from the exhaust collector so that it still sees hot exhaust gases.
Joe473
I have had an innovate single for about 4 years. It's single but I put a bung in each down pipe and swapped it when I tuned carb initially. I thought I would take it out when done tuning but it saved my engine showing dead lean condition climbing an incline one day. Turned out my fuel pump was going bad.
Yes to about 8-12 inches from collector at an angle. Make sure no exhaust leaks even downstream. (Will read lean) Make sure the engine doesn't burn oil.
Soylent
California
Angled towards the tailpipe 45 degrees?
rocknhorse76
Central WA
Yep oil will kill sensors quickly. Ask me how I know.
m_m70
Prescott AZ
I run two with true duals. Really helps with carb tuning. I run two only to help diagnose if there's a miss-fire or any other issues on each side.
