Air Shocks? Thoughts please...
jesus888
Atlanta, GA
So I just finished watching my Saturday installment of Xtreme 4x4 and they put Air Shocks on the Suzuki and removed all of the other suspension components (in this case, coils at all four corners) and it got me thinking a little...
The Suzuki sat A LOT lower but had the same, if not better articulation...
Is anyone using Air Shocks on their EB? I know there are some limitations with the Sprung weight (1000 lbs per corner max) but if I understand that correctly, that means, a 4000 lbs rig (not including the front and rear end or tires/wheels)...
I'm probably missing something here... but if I could lower my EB for convenience yet still maintain the same offroad characteristics... well, it just makes me think of this as another option is all...
Tell me why a 90/10 road/offroad rig couldn't benefit from Air Shocks...
Thanks!
ET
Dallas, TX
I'm trying to decide between air shocks and coilovers. Everyone that I've talked to suggest air shocks for truck that mainly offroad. My understanding is that if you heat up airshock, it will loss it's performance. Something about cavitation, emulsion. I don't really understand the full chemistry of it. They all say coil over if your going w/ both on road and off. I would love to try air shocks and the 2.5" will hold up a lot more weight but the price is not much cheaper then coilover shocks. I'll probably let the fab guy decide.
Eugene
burntfish
ouray, co
I have tought of this for mine also, but after being in some rigs running air shocks it change my mind. The air shocks dont always level the rig back to flat. I was in a bronco buggy in moab a few years back with air shocks and it seemed like we spent alot of time leaning to one side or the other.
burntfish
ouray, co
Looks like this while driving somtimes.
wonder if there's a way to connect the sides together to compensate for that, without losing the other features that make them desirable? Maybe an electro-mechanical switchable manifold or something.
I'm assuming that on these there is a reservoir that has a way to add/subtract pressure so you can set them up for each vehicle. Don't know anything about them though.
rwill
Would you connect the shocks together(COMMON AIR SUPPLY) or put the on seperate lines?
ET
Dallas, TX
I might have misunderstood what type of shocks jesus888 is referring to. The air shocks I'm talking about is the montube type w/ schrader valve and no reservoir. Like this.
Eugene
Although not familiar with them, that's kind of what I was figuring, since I know there are shocks that use air as the spring. Just didn't know they'd worked their way into trucks that much. And mostly too, since nobody was ragging on someone for asking about "air shocks" like Gabriel Skyjackers, and I figured there must be something newer around.
This type, I wouldn't think would normally be on a common air supply, or even have a compressor fed circuit on board. Figure they're mostly set-and-forget types. That right?
But I was thinking that some sort of manifold to allow some equalization might still have a valid function. You'd have to be able to lock it out though, or else you'd get some anti-sway characteristics that might not be desirable on the rocks.
Then again, it might be desirable, in an off-camber situation like a side-hill run or something. Not sure.
But it would interesting to find out. Maybe it's a way of having the best of both worlds.
Another line of thought though, would be that, since the air would still be acting as a spring, maybe there's a level of pressure that will encourage rebound so you don't have that sagging issue after a maneuver? Perhaps the trucks that were all wobbly-legged just didn't have enough pressure?
Whatdya think?
Any tech or manufacturer websites that might have more info? Who's are the ones you pictured ET? Are companies like Fox, Deutsch Tech and Billstein making them?
Tito
CB Fire Starter
Bakersfield, CA
Have heard incredible things about the ORIs, there were 2 Broncos at FFF running them and they were Uberpleased with them for their simplicity, adjustable valving, articulation, and body roll control. Both of course were set up with 4 links in the rear. Very nice setups.
My thought is a typical Bronco is too heavy. From what I researched a few years ago is they are for light vehicles, much lighter then a Bronco. Maybe a lightweight buggy with a bronco skin?
ET
Dallas, TX
That picture is a Fox air shock. There a lot of manufactures that makes them, king/FOA/Fox/Saw just to name the popular ones. The key is tuning them which I'm still learning.
Eugene
burntfish
ouray, co
From KING shocks.
AIR SHOCKS:
King air shocks provide a compact and lightweight option when used in the appropriate application. Air shocks ride on the pressurized gas charge inside (nitrogen). All air shocks are limited in their use by the physical properties of nitrogen gas. Nitrogen expands when it gets hot and contracts when it cools. In a lightweight rock crawler that only travels a few hundred yards during a full day of competition this is not a problem. If you plan on running on the trail or the street for any length of time it becomes an issue. When shocks work, they create heat. The heat causes the gas inside an air shock to expand which then extends the shock and changes the damping, it gets stiff. The same thing happens in reverse when the gas inside cools. If you are driving a competition only rig and are looking to save weight above all else, air shocks may be the right shock for you.
AIR BYPASS SHOCKS:
Bypass shocks provide externally adjustable damping. Bypass tubes are welded to the outside of the shock body that allow the shock fluid to flow around the piston. Each tube has a bypass valve that controls how much fluid can pass. When the valve is opened up, it allows fluid to pass easily (soft). When the valve is closed down, less fluid is able to pass (firm). The tubes are arranged on the outside of the shock according to the intended application. They are position sensitive, which means they are able to individually control the amount of damping in several stages as the piston cycles up and down. The bypass valves allow you to achieve non-linear damping curves which means you can have the shock soft at ride height for a smooth ride and progressively firmer as the shock compresses for the bigger bumps. Bypass shocks are used with an existing means of supporting the vehicle like leaf springs or a coilover. Bypass shocks are necessary if you are subjecting your vehicle to high speeds over rough terrain
Just think air over oil motorcycle fork (without the internal spring).
I am getting good at replacing motorcycle fork seals and those are very low pressure.
They are very tunable as well. Oil weight, oil level, air pressure are all the easy ones to tune without even getting into the valving itself.
br0nc0xrapt0r
Loves pickles
Air shocks are like a set of big nasty tires. If you have a flaw in your steering and suspension setup they are going to amplify it tenfold. I have no doubt that an EB with the proper oil weight and Nitro preassure would perform much better than a coil and leaf sprung EB. Both on and off road. This is saying that the 3 or 4 link suspension is set up perfect and you would be wise to use a Currie anti rock bar also. This website is a wealth of information no doubt but to get the best answers call KING. I have heard nothing but praise about the customer service they offer and I am sure they can give you a better understanding of the two shocks, both C/O Air shock and some companies like Ballistic Fab offer C/O Air shock hybrids.
