Today I install new JBG's 66-68 turn signal housings in my 76. But they do not flash when selecting a left or right turn. The wiring is pretty straight forward, I thought. Just plug into the existing wiring plug that the old stock housings unplug from and turn them on. The only difference noticed is the lack of a body ground wire from the 66-68 housings. Thinking this is the problem. I hooked up a ground wire from the 66-68 housing to the body, but this didn't help.
Here is how they are working, and yes I did remember to turn the ignition switch on when testing.
They turn on in park light mode and full headlight mode, however they do not flash left or right when selected, and neither do the tail lights.
With park and headlights off, each side comes on solid when left or right signal is selected, but they don't flash. The tail lights turn on solid as well.
With all lights turned off and emergency flashers turn on, they flash, front and rear tail lights. However in emergency mode with park or headlights on, only the tail lights flash.
What have I done wrong? Any help is most appreciated.
Fred
Fred
