Alignment Confirmation
NJBronk
I think I had it pretty close using a tape measure, but glad I took it to get a professional alignment. It rides great.
This looks pretty good, right?
This is on 32”x11.5” BFG KO2’s and new Wild Horses stock height suspension and new tie rods and drag link.
Johnnyb
Flagstaff
The only thing that catches my eye is that the spec. is for 1973-1976. I would wonder if the spec. changed when they went disks? I would expect to have a spec for '71-'75 and '76-'77.
Maybe not, but just a thought.
-JB
Apogee
Tangent, OR
I suspect that some of the difference between the before and after is just the setup on the alignment rack, because I strongly doubt they adjusted your camber or caster in any way, and the changes are so small, it could just be within the allowable tolerance limits of the measurements. Unless you have tire wear issues or something, all that really matters IMO is how it drives, and based on those numbers, it should drive pretty well.
jamesroney
Fremont, CA
You noticed that too? Good catch.
Of course the shop did not make any adjustment to the actual Caster or Camber. But I tell this to people all the time. You CANNOT measure caster or camber until you have your toe set.
There are two options to report camber. Option 1 is to report the camber with the wheel aimed directly ahead. Option 2 is to report camber with the wheel aimed somewhere else. Here you can see that the alignment computer reports the camber of the right wheel based on where it is pointed. When he took out the excess 1/4 inch of toe...the camber miraculously came into spec. You can also see the caster change just slightly by setting the toe.
Obviously you need to start from somewhere, and the alignment tech / computer decided to peg the left front wheel as the baseline, and pushed all of the error into the right front wheel. This is normal, and fine...because you have to start somewhere.
It drives me crazy when people try to "fix" the camber before they get their caster and toe dialed in. I'm glad that @NJBronk posted this so that people can see it in a single picture. It really is better than 1000 words...
And yes, as long as he runs 32 inch BFG KO's with everything new...it will drive OK. It probably drove acceptably to the alignment shop, even with 1/4 inch of extra toe. But 4 degrees of caster is the wrong spec for a Bronco.
NJBronk
NJBronk
Thanks, all.
It drove well to the shop, but even better after. Could take my hands off the wheel at 55 and it tracked dead straight.
4 degrees caster is good, no? It’s a stock-height suspension.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
4 degrees caster is good . . . . . for manual steering box and bias ply tires of the last century, not so good for today.
NJBronk
NJBronk
So stock height, power steering and 32” tires I’d ideally have more?
Not sure I’m inclined to swap the c bushings again given that it’s driving well right now…
Oldtimer
Sunnyvale, CA
If it is driving well, you probably don't want to kick the sleeping dog.
Don't know what angle C bushings you currently have, but as you increase from stock (0*) thru 2*, 4*, upto 7* you make the drive shaft to pinion angle worse.
If your like me, retired and bored, you could "fix" it, but hindsight says Broncos are supposed to be driven, not worked on.
This thread may give some insight:
NJBronk
NJBronk
[/URL][/URL]
Thanks, wish I saw that thread before!
It is driving well, but that’s also compared to it driving pretty terribly on the old suspension. I have 4 degree bushings. I’ll pay attention and maybe one day when I run out of projects I’ll swap in 7 degree bushings…
Thanks, all!
