Ok, time to verify that you indeed have a 351 first of all. But also you'll have to likely start at zero and work your way up with what you want.
Nothing you buy for a Bronco will be correct for your belt drive setup. Your pulley indicates an '87 or later part (E7 means '87 in Ford engineering number-speak) and the rest of your stuff is obviously serpentine accessory drive stuff.
So you now have a mix of parts that were never made to work with each other.
You can't just start putting '68 Bronco parts at it, or just "302" parts at it and make anything work until you use ALL parts from the same year and model engine.
Usually it's not the hood that has trouble with serpentine stuff. It's usually the radiator clearance to the fan. Got pics of your motor mounts?
And while we're adding pics (thanks for that one by the way, speaks 1,000 words), might as well show the body mounts as well. If you have crushed original rubber mounts, maybe the hood clearance was a result of that instead.
But there's no doubt that some ford serpentine drive setups don't play nice with Bronco engine compartment sizing.
The Ford Explorer V8 stuff is the best, but you need it all from the timing cover forward, and can ONLY use Explorer accessories for the most part.
