Mostly the latter. But every now and then, a young tech has read up, or learned from an old guy before they retired, and knows what to do.
You just have to get lucky. "Well, do you feel lucky? Punk!" haha!
I can tell you one thing though. A standard alignment price will go right out the window if they need to install shims in any part. Spindle, OR ball-joint eccentrics. A spindle job, which includes re-packing wheel bearings and maybe even renewing the brakes if you have not done so already, turns a $49 alignment "check" into a $750 front end refresh.
So keep that in mind.
Usually we here recommend having it checked at the alignment shop, and letting them adjust the toe-in setting. But that's about it. The rest you do yourself.
If the ball-joint sleeves are not new, then they are not coming out without some persuasion. If the tie-rod is not newer, the adjusting sleeve is not going to give up without a fight either.
So if you have not already, clean the threads the best you can, and shoot them with penetrating lube for the next few days.
Good luck! Let us know how it comes out.
