Hi, I am going to put the Bronco on a modern John Bean alignment machine. What should we set the toe to in degrees.
I have a Dana 44, 3 1/2" lift, 7 degree c bushings.
With a WH 2 way adjustable tie rod set #2403
She steers fine, no tire wear, steering wheel is centered.
I set the toe at 3/16" in with a tape. Now I just want to get my numbers, and maybe dial in the toe. The guy only knows degrees. After we check it, what is the goal to shoot for in degrees, and please tell me if this is overall, or at each wheel. I can adjust each wheel. Thank you
