All gauges reading low
oldiron
Finally got the oil pressure situation hammered out, everything is working now but all the gauges are reading low. i.e. temp shows 170 (should be 190), oil shows 10 (shows 30 on a mechanical), and the fuel wont go over 3/4 on the gauge (shows empty accurately).
I had to install a new IVR. I know this is splitting hairs but with this much time,effort and money invested I want it to be right.
Any ideas?
Greg
So it does this with the old and the new IVR? Or are you asking if the IVR will fix all the problem if you replace it? I'm a little lost on that.
Usually the IVR being out of adjustment will shift the reading of all 3 gauges mentioned just like you describe. Most of the IVRs will have a sort of adjustment that will let you dial in the offset of all the gauges at once.
oldiron
oldiron
The old IVR died an untimely death (my fault). The IVR thats in now is new.
How would you go about adjusting it?
Greg
