Alternate wire colors
BroncoJAK
Trying to put back together a badly cobbled up wiring harness. I was told its from a 93 Mustang. My problem is basically down to 3 connectors. The 8 pin connector next to the EEC is not there and the wire colors do not match anything I can find on line. The 2 round 8 pin connectors (grey and black) under the hood.
These wire colors, as well as their positions in the connectors also do not match anything I've found.
I know I'm looking at inertia switch, check engine, fuel pump relay, etc. Just looking for something that matches my harness so I could have a little more confidence in what I'm doing.
BroncoJAK
BroncoJAK
Yet again it seems I'll have a problem no one else has ever encountered.
Viperwolf1
electron whisperer
Ford seems to have had a different color code for different car models and years. You need to trace wires back to the ecm connector. From there you can tell exactly what they go to.
Steve83
I think lots of people have neglected to document the exact donor for parts they're using, and then not been able to find the specs. ;) Have you studied any tags remaining on the harness to try to confirm what vehicle it came from?
Not really. As that chart indicates, Ford tends to use the same wire color for a given circuit function regardless of year or model. But the wiring harness suppliers are allowed to match only the primary wire color - Ford doesn't force them to match the stripe color (but I've never found a wire with the wrong color stripe in the hundreds of harnesses I've worked on). And Ford does sometimes change the circuit designation, which can cause the wire color to change as well.
