I installed a cheep Sunpro trans temp gauge and installed the sensor in the cooling line out. I mounted the sensor near the alternator and just before the cooling line runs into the radiator.
The gauge worked ok, then it would bounce around then go to 0. I replaced it with another Sunpro gauge and sensor but soon after it also died. I then installed an Autometer trans temp gauge and sensor but it has now done the same thing.
I am starting to suspect the brass temp sensor that is mounted in a rubber line with an adapter is the issue because of the alternator.
I thought I would post for feedback before I moved the sensor.
