What Viper said.
Then at some point, someone disconnected the big bullet-style connector adjacent to the back of the ammeter, and put them back through the loop in reverse order.
Assuming it's still an actual ammeter, and not a replacement volt-meter instead, you can reach up behind the dash and disconnect it and route it back through the inductive loop in the reverse order that it was before.
If that makes sense...
Only with the key in the ON position though, correct?
Probably because of the next one...
There's your problem, as they used to say.
As Viper said, this is supposed to show full battery voltage at all times.
Since it sounds like all the rest of the accessories have power, then the main fusible link at the starter relay should be good.
Somewhere nearby in the harness (under the tape) is a splice where the Yellow wire is attached to the large Black wire. This is where it senses the battery voltage.
Can you post up a picture of the wiring on and around your starter relay/solenoid on the wheel well, regulator (wherever it is on yours) and the alternator?
If you don't want to become a contributor at this time, you can either use your "garage" or "gallery" functions in the user-CP, or you can e-mail them to me at
paulb@wildhorses4x4.com and I will post them up here for everyone to check out.
