Alternator question:
Started the bronco the other morning and noticed a fairly loud belt squeal that lasted about 2 secs then went away. Drove about 15 miles and noticed my alt gauge was pegged at full charge. I didn't notice this when I first started it so it could have been pegged at full charge from the beginning. The other gauges were reading normally. I didn't have the heater fan, radio, or any other accessory running (not even the lights). I turned around and headed back home and about 7 miles into the return trip, the gauge returned back to neutral (no deep discharge or charge). Took it to the NAPA store and they check the battery and alternator and all appeared to be working fine. I've driven the bronco a couple of times since then and no squeal or deep charging indicated. Is this a sign of the alternator going bad? It's the original alternator on a 29K mile original bronco.
Carb question:
Bought a 2150 Motorcraft carb from Pony Carbs. Works beautifully but I noticed a line connection at the top of the front of the carb. It looks like a vacuum line connection. Does anyone know what it's for? I've attached a pic where you can just see it under the air cleaner.
Carb question:
