laserfish
- Feb 19, 2015
- 132
While I was replacing my harmonic balancer that decided to become two separate pieces yesterday, my arm touched the alternator pulley. As the engine had not been run for over 24 hours, it startled me that the pulley was hot. The entire alternator case was hot. I disconnected the hot wire just to be safe. It is a G3 130 amp alternator that has been installed since around 2006. What could be causing this?? Also, if someone has one, a wiring diagram to be sure it is wired correctly (even though it has worked since installed). Thanks guys.
