alternator oddity
jerrybromley
So I am firing up my 67 bronco for the first time after a 3 year major renovation. I used basically stock alternator parts( 1G with a voltage regulator ) factory brackets
During break-in I had what I thought was a bad squealing belt.
After break-in I pulled the alternator belt and started it up there was no squeal. So I bought a new alternator and installed it. It had the same squeal as the original alternator...OK that's weird
To continue troubleshooting I removed all the wires from the alternator and put it back in and the belt back on.
This time no squeal :eek:
Is it possible the voltage regulator is demanding like 110% of alternator output and causing belt slip ?
mrdrnac
I'm also guessing a bad voltage Regular, but we'll wait for the experts!
jckkys
Did the amp meter indicate a high load output of the alternator? With a largely discharged battery, the amp meter reads the full 65 amps.
jerrybromley
jerrybromley
Thanks for the thought but I don't have an amp meter ..only volt meter . But I did have the charger on it earlier, to make sure I had a full charge.
I was awake last night thinking about this ( imagine that :D ) and it occurred to me my entire engine bay is coated with Raptor liner, perhaps my voltage regulator may not have a ground . Hmmmm
I can't get to it today, but I will continue checking this problem out tomorrow
jerrybromley
jerrybromley
So if you had asked me a week ago if I had put a ground on the voltage regulator I would have said " Sure ! " :-[:-[:-[
Yes, I forgot the ground to the regulator
I am how ever amazed at the out come of that mistake . That belt was screaming bloody murder . Well I won't forget that.
:-[Thanks for the input guys !
In addition to the regulator grounding to the body normally, it is also grounded directly to the alternator. In the factory harness it's just a small ground wire between the body of the alternator and the one of the regulator's mounting bolts.
Even with it grounded to the body then, it's still a good idea to have that common ground between them.
jerrybromley
jerrybromley
Thanks for the advise Dirtdonk ! I will add that ground .
So weird the sound that it made had me in the engine bay with straight edge checking belt alignment . But when I unplugged the voltage regulator and the sound went away I knew it was electrical not mechanical.
Another oddity was as I was making carb and timing adjustments I used a hot wire and remoter starter switch ( just so I turn it off and on from the engine bay) and the alternator did not make a sound ?:? LIVE AND LEARN
Boss Hugg
?:? LIVE AND LEARN
You can say and think that, but over the years, I've found myself chasing a problem with lack of starter engagement when I hit the key. Each time it traces back to shifter not being in park. ����
