Alternator questions
sixtyniner
Ran an auxillary 12V recepticle to the front bumper. When I connect a small air compressor to it the compressor runs, slow then as soon as I attach the compressor to the tire It kills the engine. Every time. Is this an alternator problem?
Can an alternator work intermittantly or partially? I have a new battery and its good but occasionaly I have had to jump it lately. My connections/contacts are all good.
Any suggestions for a replacement alternator? I plan to run a few more accessories.
S
sixtyniner
Does the compressor work anywhere? On any vehicle?
Yes it has been....However I have not tried it since. I am using a 15amp fuse. If there was short or problem wouldnt I blow that fuse? Electrical is not my strong point. I will check the compressor elsewhere........ Ok it runs fine on same vehicle just different outlet....maybe bad ground???
S
sixtyniner
Exactly what wires did you connect the receptacle power & ground to, and exactly what kind of alternator do you have? Is your alternator wiring similar to this?
I thought I was told once that "an alternator is like a fuse it either works or it dont". Well I replaced the cheap one with another cheap one, from Autozone. It all works fine now.
And yes my alternator wiring looks exactly like that.
