You have a small body 1G (first generation) externally regulated Ford alternator. Its amperage is somewhere between 42 and 63amps if it has a stock output.
As for what you need, there are lots of questions you need to answer first. What have you added for electrical load? What do you plan to add? Where do you drive, i.e rock crawling or mudding, or just pavement with some average dirt trails?
I think at last count we have well over 20 alternators that fit your application. Only about 8 that are common though. Anyway if you want to walk yourself through this web page,
http://www.svapowerproducts.com/html/how_big_of_an_alternator_do_i_.html , it is an attempt at explaining what size of alternator you need.
After that, you can then figure out what type of alternator you want, i.e. Delco 1wire, 1G small body, 1G large body, 3G small body, 3G large body, 3G high output, etc, etc.
If you get stuck on something, give me a call at 1-888-214-7774.
