3g alternator got it thanks though
johnmlebel
is there a 3g alternator that bolts in like the stock one from the eb an use the v belts pulley?
73bronco
Most will.....Mine came out of a 93 Ford Taurus with 3.0. I then changed the pulley to the stock v-belt pulley off the stock Bronco alt. You can't use the fan behind the pulley but the 3g is internally cooled.
x2. Only some of the later ones were the "side mount" types that only fit the later Mustang and Explorer serpentine kits.
Check out Ryan's site at www.fordfuelinjection.com or www.rjmtechnologies.com (I think?) and there are some pictures and applications for the one you need and descriptions so you can tell the difference among them.
Or someone probably has the full list that they'll post up even before you get to the Ryan's site. But it's some good reading, so check it out anyway when you can.
RRRAAAYYY2
Brantford, Ontario
There are a couple of differnet styles that will fit. None come stock with a V groove pulley, you have to add that yourself or buy an aftermarket alternator with one already on it. You will also need a wiring harness or plug to adapt into your old wiring.
There is also a GM alternator that will fit in place of your old Ford alternator, they can be made one wire hook ups too.
Pedestrian
Bronco Missionary
I used one from a 95 Mustang 5.0. Just swap pulley from your stock alternator. Easiest upgrade I've made.
J
johnmlebel
i have a newer motor with the side mount and it is being a pain. i knew none came with a v belt pulley, thanks though. I ended up just going out and using the book at work and found one i wanted. Not sure if ill need to change it out et or stick with the side mount one i have in now
RRRAAAYYY2
Brantford, Ontario
I can build you anything you want. If that helps at all.
KyleQ
We swapped one in at camp this weekend - chased some wiring and got it working. Took no more then 30 minutes to do with minimal tools on a muddy and wet truck.
450rbronco
can you tell us more about your ez alt swap i need to do someting and im looking for esay udpgrade that will put out more than stock
450rbronco
what do i do with the other wires that went to and from the old regulator and the ground wire hooked up at regulator do i still need it ?? what about the big pilll looking thing that is hooked to the reg. also i have a wire coming off of my alternator going up to a terminal on my factory carb what do i do about that
what do i do with the other wires that went to and from the old regulator...
The Orange "Field" wire is simply eliminated. It only goes between the old alt and the old regulator anyway, so it's function is now strictly internal with the new alt.
...and the ground wire hooked up at regulator do i still need it ??
Nope. It's going to go away with your old harness, just like the Field wire is. It never hurts to have a ground wire from the alt housing to the body, but you can make up your own in any orientation you want. Run it to the engine, or to the body. There should be a ground stud on the back of the new alt. Just run a wire to your engine, like somewhere on the intake manifold, and also make sure your engine has a good sized ground wire/strap from the intake manifold to the firewall.
...what about the big pilll looking thing that is hooked to the reg...
That's a radio noise suppressor. Just heave it, unless one of the experts says there's a way (or a need) to mount it to your new alt. I don't think so, since I've never seen one on a newer alternator, but let the others confirm that.
The Yellow wire that it's hooked to though, is always hot (full battery voltage all the time), so should be carefully capped off so it can't short out on any metal.
...also i have a wire coming off of my alternator going up to a terminal on my factory carb what do i do about that
That's your "Stator" wire and Broncos use them for the electric choke. There is probably a "STA" terminal on the new alt. Simply hook it there and you should be good.
It's used for dashboard indicator lights and/or automatic chokes on carburetors.
An like was said previously, check out the BCB diagram and/or any that Viperwolf and the others have posted up, to make sure you don't re-use the original Bronco charge wire.
Like the Yellow wire mentioned above, you need to either disconnect the large Black, or Black w/yellow stripe (depending on year) wire from the back of the alt and cap it off so it doesn't cause any trouble.
Crimp it, cover it, tape it, or terminate it on a stud somewhere, but keep it out of harm's way since it also has full battery voltage all the time. Which makes it good for running accessories from, but also makes it a prime trouble-maker if you don't take care of it.
That's what the new, larger 4ga wire takes the place of.
450rbronco
ok thanks guys ii was gonna order all my stuff from rjm but havent got the email back from him on if he reccomends i have the 95 amp 3g or the 160 amp i guess ill cap wires up where reg is or was and cap them where they hooked to old alt cause i dotn wanna really tear the old harness in between apart . will the 3g alt have the spot to hook my wire that goes to the electric choke
He, like just about anyone else, will probably tell you to just go with the 130 for the same money (if you're getting from junkyard), but which one you use won't have any real effect on the wiring installation.
Even with the 95, you should still use the upgraded charge wire described in many diagrams. The only exception to that might be with a brand-new harness with sufficiently sized wires. But even that's not a real justification for doing it that way. Best to keep any charge wire as large, and as short, as possible. It's better for charging, safer for, well, safety's sake, and easier to route.
There's just too much chance for an issue with a high-output alternator putting it's charge to the battery through 20 feet of small gauge wire with potentially rusty or loose connections in-between.
So the bottom line is, even with a "measly" 95 amp output, run a short 4 gauge charge wire to a mega-fuse (or equivalent protector) and to the battery. And RJM sells the proper connectors for the different generations of "generators."
That may not really be what you were asking or waiting for from Ryan, but it's important enough to re-mention.
Use whatever alternator you want, but going with the slightly larger 130 amp stock unit, or even an aftermarket upgraded 160 amp unit, is just icing on the cake. Bigger is often better, charging-wise.
Pretty sure all 3G's have the STA hookup. Should be able to find the markings on the case or in the diagrams online.
450rbronco
ok thats why i was planning on going the rjm way was cause he had the harnesses for a clean hook up . i saw on a chart somewhere it looked like at idle like 1000 rpm the 95 put out less than stock . all he lists on his site is a 160 not a 130 but i seen something about calling it a 160 cause it can put out that much but is also reffered to as 130 i think i saw that on bcb site??
i just didnt want it to be to big and hurt something
Ok, gotcha. The 160 rating could be either for that reason, or because some people make them to put out more than stock. You can't call all of them 160's though, because they won't all put out that much. It's not uncommon to get 150 to 160 in testing, but you can't change the name for just "some" of them, so he's probably got some specially wound ones for sale? RRRAAAYYYY does that with alternators too.
Anyway, no such thing as too much, in the way you're thinking. The alternator only puts out what it's asked to. So even a 250 amp alternator is only going to put out 10 amps, if that's all that's required of it at the moment.
That's what the voltage regulator is for.
