- Joined
- Nov 3, 2003
- Messages
- 49,425
The AAW kit is not set up for a stock alternator or external regulator. You will need to supply your own internally regulated unit, charge wire, or make your own stock harness from readily available stuff if you want to stick with stock stuff.
The stock ammeter is non-functional in any way with the AAW harness. There is not even an included circuit to make it work.
This is why they recommend (or apparently include, which I did not know or had forgotten) a volt meter instead.
Both of the others are compatible with upgraded and internally regulated alternators, but still include wiring to keep the ammeter functional with alternators up to about 70 amps or so.
(by the way. The Bronco's semi-unique fully inductive ammeter gauge is completely safe from overload and burning out or shorting out from too much current flowing through it. It's the wires themselves (just 10ga) that could fail if overloaded from being used with a too-powerful alternator. The more common type of ammeter is not recommended for use with anything larger than it's stated capacity as it can short out and cause a fire. Which is much of why ammeters fell out of favor with many to begin with.)
You never need a separate harness for a Pertronix Ignitor. It's a stand-alone unit with it's own two wires that you connect to the existing ignition power wires, which all three harnesses do provide.
The AAW is still a nice harness, made to excellent quality standards. They just feel you should upgrade to a more powerful alternator (like most of us do already anyway) and sort of force your hand by not including anything for the old charging system.
Their Mui-Bitchin' Heavy Duty harness (http://www.wildhorses4x4.com/product/American-Autowire-Severe-Duty-Universal-Harness-Kit) has a similar expectation, but is universal and not Bronco specific in any way. And it would require the most input from the installer.
But it's the coolest of the bunch too!
I don't consider ANY of them to be truly Plug-n-Play like you might hope. There is a lot of work to finish off any installation of any of them. The Painless is the most "Ford-like", the Centech is the most "finished" and the AAW is very well appointed and customizable for a middle-of-the-road price.
Sorry I don't have info on the gauge yet either. As I mentioned I either forgot it was included or never knew. I'll see if I can get some info and add it to our site.
