Hey mofohella, all kidding aside, you don't really need any lift for that size tire.
You most likely won't fit them under un-cut fenders without a lot of lift, but if you cut the rear for flares, then trim the front a little, you can fit 32 x 11.50 x 15 tires under a stock-ish Bronco.
Most appropriate wheel widths would be 7 or 8 inches, but even 10's will work if you must have that deeper look. Frankly though, a 10 is a bit wide for that style of tire on a Bronco.
