I have scoured the site and apologize if this is redundant redundant.
1972 Ford bronco. Original wiring. The front blinkers work. The rear passenger side blinker and brake light work. All running lights work. All fuses intact.
The front driver side blinker works. The rear blinker and brake light do not work. New two-wire connector for the rear blinker/brake light, fresh ground at the left rear light assembly. The bulb works when powered by a separate 12 volt source.
So what is next? 1) hand over hand follow the wire to the front? I believe the left blinker and brake wire is green. 2) disconnect the blinker wire connector under the dash and apply power to the left blinker post? 3) Check the blinker switch at the steering wheel somehow ?
I dunno. Thank you for any help. I am missing something.
George
Arizona
George
Arizona
