Another Bukin Suspension Mod
Bukin 67
Bukin 67
Bronco Abuser
Thanks !
Here are a couple of pics prepping the front end for the cage, suspension and steering mods.
Bukin 67
Bukin 67
Bronco Abuser
we did some frame reinforcements and an F150 steering box mount
nlped
Dang, The welding looks amazing!!! I really like the way you did the reinforments...the cutouts were a great addition, both for strength & looks. The rear 4-link arms are gonna match... I like IT!!!
Bukin 67
Bukin 67
Bronco Abuser
Thanks nlped. The welder has it in his blood. He's really an artist at it.
We're about 75% done now. After all this I'm having 2nd thoughts as to if I should have waited to save up for a nice Curry rear end instead of customizing the stock 9" housing. Everything internal has been done - chromoly axles, locker, etc., but disc brakes and a beefy housing would have been nice.
I have also been looking into a serpentine swap kit using as many new kit parts as possible. The problem is since everything is "backwards" as far as water flow I can pick up an entire used EFI motor, complete with computer and brain for that, and when I look at the accessibility we have now with the front off...
It won't be ready for Thanksgiving by any means, but I should be able to bring it to Truckhaven for New Years. Really looking forward to some test running.
Bukin 67
Bukin 67
Bronco Abuser
Keeping the updates coming..
Steering box installed
Engine compartment/ front shock tower framework started. Partly removable (of course) to make way for the future home of a EFI 5.0 HO
What a messs...don't look too close at the wiring %)
Bukin 67
Bukin 67
Bronco Abuser
Thanks Stephen, and everyone for that matter for your compliments and kind words. I only wish I could lay claim to those welds and fabrication skills. The lead welder's name is Loco Jones at Temper-Mental Racing. Loco and TMR are well known in the off road racing circuit out west. Outside of their other current projects, they're building a trophy truck to compete in the south western circuit and SCORE.
They started racing jeepspeed class and went on to class 5, 10, 11 and 18, among others. The last TT they built competed in the DAKAR Rally earlier this year and took 28th overall and 3rd in class I believe. They also have a few 1st place victories in the Baja 1000, one of them iron man by the owner Jason LaFortune. That was a long day! :)
I've known these guys and chased for them many times over the past 10 years. To say I have a lot of confidence in the team at TMR is really an understatement.
rbodine
Wow, amazing. Is this going to be used as a race bronco when it's done? I read thru twice but didn't catch that.
Bukin 67
Bukin 67
Bronco Abuser
Thanks rbodine. When it's done, mind you I still will be replacing the motor and dash at a later time, I plan on using it both as a prerunner and. crawler. I do plan on racing the vintage race in Baja, but that's just for fun. it no longer classifies as a 'vintage' per say, but that class is title only and the rules are really loose.
Bukin 67
Bukin 67
Bronco Abuser
actually the word 'done' doesn't really apply to early Broncos;D
Bukin 67
Bukin 67
Bronco Abuser
Continuing with the front suspension and ram assist steering mods, we reinforced the pitman arm for the heim joint attachment.
Bukin 67
Bukin 67
Bronco Abuser
A little more progress before we take the week off. I wish it was ready, I'm headed to Soggy Dry Lake in Johnson Valley for Thanksgiving and there's some awesome 4 wheeling there. I'll be quad riding with the wife & kids this round.
Here are Pics of the D44 with 3-link setup and a close up of the mount for the track bar.
Bukin 67
Bukin 67
Bronco Abuser
I haven't posted anything in a while. The shop got sidetracked by some other projects that needed to get done for races that were coming up before I needed mine.
At any rate, she's home now and I've been working on the wiring mess that was left after moving so many things around. I've made some pretty good headway in the engine compartment. Since I don't have any mounting places left in the engine compartment with the inner fender wells gone, I need to relocate the ARB pump to the bottom near where the aux. fuel tank was. I would put it right up in there except the C4 cooler and fan fit in there perfect. I need to run a snorkel off the ARB compressor up through the floor under the driver's seat, but I don't see an inlet where I can attach it ?:?
The bi-pass are on order and will hopefully be here for the Tierra Del Sol event on March 1st. After that It'll be back in the shop for some mods to be NORRA legal.
Bukin 67
Bukin 67
Bronco Abuser
Getting some progress on painting the tubular engine cage and cleaning up the wiring under the hood:
Bukin 67
Bukin 67
Bronco Abuser
The exhaust is routed to a single and out the side in front of the rear tire on passenger side (The wire loom in the pic is gone):
Bukin 67
Bukin 67
Bronco Abuser
Batteries are installed in the rear, and we're working on boxing in the shocks:
Bukin 67
Bukin 67
Bronco Abuser
The front suspension and steering turned out pretty clean:
Bukin 67
Bukin 67
Bronco Abuser
I installed a (made in the USA!) Rigid LED light bar with combo flood and spot pattern 3.375" high 3.625" deep 51 3/8" wide.
We fabricated some custom brackets to either side of the windshield, then attached the windshield frame to the cage for rigidity.
broncoitis
Holy Crap! That is just gorgeous workmanship!!!! Love all of it. Truck is gonna ride like a magic carpet everywhere. :eek:
