Another casting number thread Solved?
oldiron
Just picked up another engine to build and keep as a spare. I believe I've gotten the dates all hammered out, but a few are confusing me. They are as follows.
1: Casting number above the starter is C8OE-6015-A with a cast date code of 9E8 right above it. Should be may 8th of 69?
2: Assembly stamp on the pad below the dist is (and this is where i'm stuck) 9E9K. What is the K? Assembly of may 9th?
I've never seen an assembly date so close to a casting date before...1 day?
seems odd.
I'm hoping others can offer a little light on the subject.
Greg
rmk57
Only thing I can think of would be the assembly plant. K would be Kansas city and I dont they assembled Broncos there. W is the Wayne plant and F is Dearborn.
oldiron
oldiron
After hours of searching I "may" have an answer...
most believe that the last letter after the assembly date code was the initial of the inspector, who signed off on the final assembly of the engine before it left the engine plant. There are a few who believe it may signify the engine plant itself..i.e. c for cleveland or w for windsor. But I can't find any engine assembly plants that start with a k. So I'm leaning more towards the inspector initial scenario. Another theory is that this lettering was a form of internal coding or communication within an individual assembly plant and therefore no records likely exist.
I'm still a little stumped by the timeline though. It's hard to imagine that this engine was cast on May 8th and assembled on May 9th, but that's what all the numbers are pointing to.
On a positive note it appears that this 302 is completely intact and original, dates for all the components are within a few days of each other. Confirming what the p.o. said about it being from a 69 Bronco and not pieced together from a collection of parts.
Greg
broncnaz
Read somewhere that back in the flathead V8 days 1932 ish a engine could be finished in 120 mins. So its not really out of line. The whole process was Henry fords signature assembly line. wasnt clear if that was from scrap steel to finished engine but that seemed to be what they implied.
So really a one day differance is not that out of line. Plus who knows casting dates may be a little off as production could start earlier or late depending on things that happen Im sure molds were made somewhat ahead of time so date codes were set with what they thought they could set in a schedule. while the stamp was made probably made by hand on the day it was done.
As you indicated I think the K is more of a inspector/internal thing and has no real meaning
