Another Centech question
IPwizard
NE Ohio
I was looking over the destructions on installing the Centech harness. I cant find where it says how big the holes should be in the fire wall for the harness.<br><br>Where did you guys drill your holes? Pics?<br><br>Thanks<br><br>
cjjhalfcab
Oologah, OK _
My destruction manual says for the early models with the center fed harness, you drill 2- 1 3/8 openings at both ends of the firewall (pg. 2, #14). General locations are on pg. 7, if our sheets are the same. Mine was a later year, and fed through the sides already.
IPwizard
IPwizard
NE Ohio
I guess reading is key, I must have read that page like 2 times and my dad a couple times looking for this info and never saw that. :)<br><br>Thanks for shining the light on me.
cjjhalfcab
Oologah, OK _
[quote author=Ford_Tuff link=board=5;threadid=14324;start=0#107958 date=1045373889]<br>I guess reading is key, I must have read that page like 2 times and my dad a couple times looking for this info and never saw that. :)<br><br>Thanks for shining the light on me.<br>[/quote]<br><br>I don't know why they put that info about half way into the harness install instructions. There were a few things I couldn't figure out, and after I called their tech dept. they were plain as day.
IPwizard
IPwizard
NE Ohio
[quote author=SteveL link=board=5;threadid=14324;start=0#107981 date=1045388958]
so hard to read when you're used to just looking at the pictures
[/quote]
;D True, True...
Can someone tell me where the hole should be drilled on the passenger side? The pic on page 7 doesnt really do a good job. Is the hole above the heater box or something?
Thanks.
IPwizard
IPwizard
NE Ohio
Thats all good, but my Voltage Regulator is on the driver side core support. :D<br><br>Could you measure from the inner fender to the center of the harness, and and down to the center for me?<br><br>Thanks.
