Another Chevy Disc Conversion question!
604birdman
Ok, so i have searched, and read, and read again but i cant seem to find the answers i need.
Where i am, early 70's chevy D44's are just as scarce as bronco D44's so looking for some help, or "cheating" as per say with the swap on my 69 with a D30.
Can i use 76+ GM spindles? if not, why?
Can i use 76 + GM backing plates? the backing plates ive read some guys use all the way upto into 85 for the swap which would help me alot since there are more 80's squarebody trucks where i am.
Can i use my stock drum spindle with the 76+ GM backing plate? there was talks awhile back about a "spacer" and some dimension were mentioned but i cant seem to find this thread anywhere.
toddz69
You can certainly use the '76-newer backing plates. There were several different styles through the years all the way up to the end of straight-axle Chevys and Wagoneers in '91, but they all work.
You could use larger '76 spindles but they would require machining on the inner bearing surfaces (I think some people do that), which seems like a lot of extra work to me.
There are various threads like you mention, about using other parts to get the drum parts to work. I like easy to use, non-modified parts on consumables like that so I usually don't bother following all the details.
And yes, it's sad that all the used spindles, etc. have disappeared over the years. I pulled and sold dozens of them in years past. I used to pull and sell backing plates by the dozens too. Somewhere I have a pic of a pile of them in the bed of my pickup after a picking expedition.
Todd Z.
604birdman
Todd Z.
Thank you for the reply Todd.
I definitly dont mind a little more running around and mis matching parts to get something to work, and save a couple bucks. being in canada, a current bolt on kit would cost $1000CND, so even if i can save half id be happy.
Does anyone have the specs for machining the 76+ spindles?
how about making it cheap? make a 3/16 thick spacer for your stock spindle with the od same as the innerspindle bearing which is like 1.55 od and the inner bore the same as the spindle. needs a big chamfer on the backside to clear the inner spindle radius. there are write ups on this site.
Yeller
Rogers County Oklahoma
I wound up machining a newer set on my last conversion. Pretty simple if you I know some one with a lathe. The inner bearing diameter needs to be turned down, don’t remember the dimensions off hand.
