Sporto
- Oct 10, 2005
- 923
OK,
Have a basic older 302. Did an EFI conversion a year or so ago with an 86 Mustang GT Speed Density setup. Run the two pump (Carter LP -> E2000 HP) setup. Harness is setup with added relays and fuses.
Everything runs great, and has done so for past year. Recently had an issue...Engine died on highway. Nursed it home, check engine light came on, ran codes ended up with code 87 ~ Fuel Pump issue. Swapped out FP relay, problem solved.
Now I get this problem sometimes. I drive it normally, I shut it down (for the day or whatever), then go start it. No priming of pumps, no start, CEL comes on. I pull the fuse to disconnect ECM and I take out FP relay. Let sit for a minute or two. Reassemble, pumps prime, no CEL and engine starts no problem. This happens sometimes, and I am not sure what is causing it.
I tried several relays when it is offline and it does not make a difference. It just needs to sit for a few unplugged and it works again.
Just not sure what is going on...
Setup ~
86 Mustang SD
ECM ~ VR1
Codes ~ Just EGR ones
Stock orange injectors
Stock TFI distributor
302 with Edelbrock Performer Cam
Stock Manifolds
O2 sensors in each pipe
Thanks for any advice!
Rich
Setup ~
86 Mustang SD
ECM ~ VR1
Stock Manifolds
Rich
